Big Grid on Responsive Problem
i’m using Big Grid for my layout, the problem arise on responsive element, the Big Grid does not convert into single coloumn..
anything to do ?
Hello admindoxa,
Please notice that our Big Grid element has been designed to be responsive, as you can see in our demo preview, here -> http://demo.tagdiv.com/newspaper/big-grid-1/ You can shrink the browser and you will see that the Big Grid is responsive one. Also, please notice that if you are using some untested plugins in your theme, these might interact with the theme’s code and might appear a lot of unknown issues. Please try to disable all the active plugins, leave just Visual Composer to active, clear all your caches and install only the plugins that come bundled with our theme and rule out the conflicting plugins. Try to bring the theme to the default state and check the results.
If your problem is still there after these tips, please provide your website URL so I can inspect it closer your Big Grid element and also, so I will be able to provide a more accurate response.
