big grid slide tags and titles problem
On Safari (iOS 8 and Mac OS 10.10), the titles and tags on a Big Grid Slide disappear after the first slide. To make them appear, we have to scroll up or down the page, but again after the first slide, the text will disappear…
Could you help please?
If needed, I’ll PM you the website address.
We will need to inspect this issue ourselves and we cannot recreate it on our end. If you do not want to post your website on this forum, you can send us an email at contact@tagdiv.com. Please include a link to this topic and you could also provide us with a username and password in case we need to access the back-end of your site.
I’m facing exactly same problem in the Safari browser.
Is there a proper solution to that issue?
Thanks heaps
Yes, the problem is present and we will fix it in the next verison of our theme. until such time please try to add this code in the theme apne-> custom css box:
.td-big-grid-post .td-meta-info-container{
position:absolute!important;
Unfortunately, it didn’t work.
I’ve tried to put the code in the Theme Panel > Custom Code > Custom CSS and also directly in the Style.css. Both unsuccessful.
>> http://waves.siteprovisorio.xyz/
That’s is a quite critical issue, please we need an urgent solution or at least a solid release date of the next update.
OK,
Please try to disable all plugins except the page builder, clear cache and reset cdn files if you use it. Please also remove any optimization tools for testing purposes and see if any affects your slide element.
Bogdan B
Hi Bogdan,
We deactivate all plugins and cleaned up the cache but again with no success. We’ve noticed that the info appears on scrolling the page. Could it there’s something related to the issue?
Please check again as I cannot see the issue anymore. Maybe your cache was not cleared.
The grid seems to work properly now.
