I’m using v9.0.1 and noticed new width and max-width attributes on the images for Big Grid Slide > Grid Style 4- Bottom Box, which is causing 3 smaller-right-images to be cutoff horizontally vs filling the space.
View here on homepage: staging2.thehawaiiherald.com (v 9.0.1)
Not here on homepage: thehawaiiherald.com (v 8.5.1)
Is there an aspect ratio now being applied to these images now?
If so, is there a way I can comment it out? Thanks
<img width="284" height="160" src="https://staging2.thehawaiiherald.com/wp-content/uploads/2018/08/Okinawan-FestivalLeinani-Group.jpg" alt="Leinani Group from Okinawa will be part of the formal opening ceremonies on Saturday." />
It is look like your image are smaller that the thumb and it need to be zoom .
https://www.screencast.com/t/gsUVtmFzASF
For full width please insert the above css :
.td-big-grid-wrapper .td-module-thumb .td-image-wrap img{
width: 100%;
Go in Newspaper > Theme panel > Custom code > Custom css and paste it there.
https://www.screencast.com/t/ioObsvFca2b
https://www.screencast.com/t/GMOUkdKE4MD7
