Big lag problem on the Home
I have some lag problems on the subject. A week ago we had excellent scores on GTmetrix, Google Page Speed, PingDom, etc. Now the site has slowed down a lot after I changed the theme this past week. In particular, when you enter the theme there is a very strong lag with a zoom effect on the entire header (menu and logo) which then returns to normal size. Is it possible that many changes have damaged the theme code? Can you do a check? I contacted my host (Vhosting one of the fastest in Europe) and they do not encounter any problems. I can therefore imagine that the problem is the theme and some code on the home. Can you do a check?
this is the zoom effect you see when opening the home page https://ibb.co/1rLNS0G
This causes a strong “lag” when opening the page. Before we had an opening of the home under the second while now we are at 2 seconds.
My site is: https://www.moviemag.it
Why don’t I see an answer to my problem? Is there assistance for everyone or do you make distinctions? I see that Vlad, Bettina, etc. they answer everyone but not my messages. Okay, I’m waiting for Calin but you are unprofessional.
Hi Lacasito70, sorry that is take so long until you get a reply!
Usually the ” zoom effect” appears when you enable this option on cloud header -> https://i.imgur.com/FZa9dpa.png
Also you need to re-optimize the website for the actually changes that you’ve made when you changed the theme, in this way the new changes will be optimize.
Hi, the option you indicated in the screenshot in my menu is already disabled. I believe the problem lies elsewhere. Also, how to do the re-optimization? You say we need to re-optimize but I don’t know how to do it.
Now that most of your theme layout was change, you need to do again the steps for page speed, or at list to check theme to make sure that are still set correctly and the cache and cdn were cleared.
Also is possible that your cache and cdn to be already adapted because now you have a very good score -> https://i.imgur.com/b3W14cj.png
If you still want to check the pages peed guide you can do it here -> https://tagdiv.com/how-to-increase-page-loading-speed/ and this is also a very good guide https://www.infophilic.com/get-almost-100-pagespeed-newspaper-theme/
