Big problem
I have a problem because I can not use ADD ELEMENT!
I have this message: Errors happened during tdcIframeData.init () -> bindViewsModelsWrappers ()!
And impossible to put new thing
(Pardon for my English because I am French)
thank you very much
If you have the Yoast SEO plugin installed, please check and disable this setting from the plugin
https://www.screencast.com/t/n8Cc35EofLh
Then check and see if the composer is working properly.
