Hi, I never had this problem on other sites. Let me explain … For the moment I have not allowed anyone to register on the site, I manually register them to do tests, the problem is that after registering them and receiving the email, in an attempt to log in, I always reply with a username or incorrect passwords. I have and have tried to reset the password but the problem does not change.
I discovered the problem where it comes from. If you enable the Google Captcha plugin (reCAPTCHA) by BestWebSoft users can no longer log in if you deactivate it, the problem vanishes.
I have another question. After login the user is sent to the bulletin board page, how can I send it to the home page of the site?
I really can’t understand … locally I have the same site installed with the same plugins yet, when the user logs in, the site homepage opens and not the bulletin board … The online site instead shows the bulletin board and not the homepage …
I repeat I use the same plugins, same theme, same version of wp.
What I would like is to be able to make the user, once logged in, be redirected to the home page or buddypress profile
