BIG PROBLEM – theme destroyed?
I got a big problem – visited my website today and it’s totally broken – didn’t do anything but updating 2 plugins… deactivated both, but still broken. Any ideas??
http://www.deinpekawe.de/ <- websitelink ! THANK YOU
seems like all options in the THEME PANEL are deleted – do you know where they are saved? in which folder on the ftp? maybe my backup can help me.
Theme options normally saved in the dbase.
Make sure you’re running latest version of WP, as ALL older versions have major security flaw.
Hello
I have checked your website and I saw that you have some errors in your console as you can see here -> https://www.screencast.com/t/qCnAxWYGiS8 These type of errors could come from your untested plugins which might interact with the theme core files and cause a lot of unknown issues. Try to disable all of these, leave just Visual Composer to active, clear all your caches and install only the plugins that come bundled wit the theme packet and rule out any conflicting plugins. If the problem is still there, you should make a new clean install from scratch via FTP and check the results.
