Hello, I am working on the site for two months. I would like to launch in monday. I firstly I build it on the Newspaper 4.6. and upload TAG DIV SPEEDER. When I moving to 6. I was rewrite New version of TD SPEEDER by old. But site crash. When I delete it it was functional. I complated migrantion to six and know try upload new TD SPEEDER what i get with Newspaper 6. ANd whole site collapsed. I try to delete it. Ano nothing. Site is collapsed and I dont know what to do. I dont want to make whole site from scretch. I wll be happy for help. You can try http:/www.xczech.com. Nothing. Internal ERROR. It is not proble of webmaster because my second site is fully functional. I am really detroyed. It is 2 months work! Server is causing 500 Internal Error.
Can you help? How can I delete TD Speeder from database?
Jan
Try renaming your plugin folder via FTP to xplugins, then login via admin. You should be back to your website.
Delete the plugin which appears to conflict with something ELSE you’re using and not the theme.
Then try renaming the plugin folder back.
Try logging in again. Then DISABLE all plugins except Visual Composer; re-upload via FTP fresh copy of the tag div speed booster which comes with NP6 (LATEST VERSION); then activate speed booster plugin.
If site works, then turn on other plugins one by one to see which one is the problem.
If you’re using caching plugin, caching service, you have to turn those *OFF* whenever you do major updates to your site or turn on new plugins which “rewrite” page content.
YOU ALSO DON”T NEED TO TYPE ALL CAPS AS THAT CAN GET A BIT ANNOYING TO READ FOR FOLKS HERE.
simchris.
