BIG PROBLEM WITH NEWSPAPER
Hello, today i updated Newspaper Theme and the web site has changed dramatically.
The footer has disapperead, the header and the widget are different. What is going on?
I want to come back to the previous version of Newspaper, this one is really bad.
1. disable TagDiv Composer
2. uninstall TagDiv Composer
4. install TagDiv Composer
5. activate TagDiv Composer
6. clear cache (if cahce plugin exists)
Also make sure your WordPress and plugins are up to date.
Sometimes, the issue can be from a plugin conflict, that’s why, please deactivate ALL plugins except tagDiv ones, also if you are using a cache plugin, deactivate it, clear all cache and try again.
Let us know about your results!
