I have a big problem with the “footer”. I don’t know what happened but I see the footer on the homepage but on the article pages or entering the categories it is not there. I tried with edit with composer —- manager —– footer but I haven’t solved it. I have tried to deactivate and activate composer and I have also emptied the cache without having any result. My site is https: http://www.moviemag.it
I await your response on how to resolve the problem.
You should access an article from your website and check in the website manager if there is assigned the correct footer or not. The same thing you need to do by accessing a category.
If this is not helping you, then please make a full backup, send an email at contact@tagdiv.com and provide wp-admin, so we can investigate this issue. Also paste a link to this topic so we can easily identify you.
I went into cloud templates —> all templates —> single article and also in category but the problem was not solved. I select in “manager” footer and then “footer pro” but the footer does not appear. I believe there is a problem because the footer on the Home is visible instead in the articles and in the categories it is not visible.
Please make sure the footer you need is set it as Global in the whole website: https://www.screencast.com/t/kVf0wDWLi
Hope that helps you!
The problem is not solved. I select the Footer but it doesn’t appear below where you see the arrow. I see the footer only on the Home. In the articles, pages and categories it is absent. https://ibb.co/2WD3v0Y
