Big slide problem
I have a problem with Big Side on my home page. The photos do not display correctly.
>> http://blogzineauto.com
Do you have an idea of the problem ?
Thank you
This may happen because of VC plugin, please make sure you use the latest theme version(4.2.2) and also the 4.3.3 version of the VC plugin, we have fixed this in the last version of the theme.
You can fix this by adding this custom css in theme panel > custom css field to solve this:
.vc_col-sm-12 {
box-sizing: initial !important;
Should work like this: http://screencast.com/t/KVD7uJgev3h
Lucian,
Yes i have the latest theme and plugin version. But it works with the custom css. Thanks 😉
