Big Slider on Homepage not working – clicking does not go to post
Hi there,
My name is Haresh and our site is already live at http://www.balukoo.com. Unfortunately, the ‘big slider’ on the homepage is not working. The posts do rotate, but clicking on any of them does not result in anything. The link seems to be broken.
I have checked this forum and looked it up online, but can’t find anything. Other users seem to have similar problems though. What can be done?
Haresh
after updated newspaper theme to version 4.3
main page of our site (http://www.sjzine.com) has got same problem too
please let me fix it problem
lee
  • This reply was modified 12 years by jjailbird.
This issue happens when using the Google Analytics by Yoast plugin and looks like that some how the plugin is affecting the html structure.
We have already wrote to plugins author so we can find a solution for this, you can also write to their support page: https://wordpress.org/support/plugin/google-analytics-for-wordpress
we are trying to fix this but unfortunately is more difficult than we initially tooth. You can deactivate the plugin in order to make links work and until we find a solution for this.
  • This reply was modified 12 years by Lucian.
thanks ~
Any News?
We are trying to fix this but unfortunately is more difficult than we initially tooth. You can disable this option from Yoast Google Analytics general settings, will fix the issue with the links: http://screencast.com/t/LRV9LlBn3 or you can also use our own Google analytics support (just paste the code in our admin): http://screencast.com/t/EtxOCuXlspj
Sorry for the inconvenience!
