Something is wrong with my big slider.
http://www.biznesinteres.ru
It is set to a category filter that has 4 posts.
http://biznesinteres.ru/category/interesting/
But as you can see it’s not displaying correctly after the update.
Thanks in advance!
This issue appears when using the 980px layout, please try to use the 1170px layout instead we will fix this in the next theme update.
If this dose not solve this problem please make sure you clear CDN cache and also clear your browser cache and check to see if this issue is still present. This may cause this issue as your CDN delivers the old versions of the files.
You could also try to regenerate thumbs https://forum.tagdiv.com/how-to-fix-strange-thumbnails/
How long until we can expect a fix? I sell the the site skin (background ad) and need the theme to be in 980px to do that.
I am also experiencing a problem with the Big Slider on the latest update, in 980px responsive mode. The problem is rectified when using a 1170px layout, however I would rather not use this mode.
The problem is only apparent if the window is large.
How long until an update will be released?
