I have three problems so far in a new installation of newspaper theme
1) BigSlide leaves large whitespace… can you tell me why?
http://mobile.neakriti.gr/sandbox/problems/bigslide.jpg
2) Slide leaves spaces too
http://mobile.neakriti.gr/sandbox/problems/slide.jpg
3) selecting “Homepage with bg” as page template sets up the background, but leaves the big slide empty
http://mobile.neakriti.gr/sandbox/problems/slidebackground.jpg
Any help plz?
This topic was modified 11 years by
neakriti.
1&2 Please try to regenerate your thumbnails: https://forum.tagdiv.com/how-to-fix-strange-thumbnails/
After doing this empty cache and check again.
Also note that if you have featured images smaller you need to use a plugin like Thumbnail Upscale: https://wordpress.org/plugins/thumbnail-upscale/ as WordPress cannot enlarge thumbnails, only make them smaller. For upscale use a combination of plugins Thumbnail Upscale + Force Regenerate.
3. This should not happen, because the background should have negative z-index. Please try this custom css in Theme Panel > Custom Css: http://screencast.com/t/4Tyxyq5OJ
.td-big-slide-background .backstretch{
z-index: -999998!important;
Please provide your site url if this not helps.
1 and 2 remains a problem
My URL for my “test site” is http://mobile.neakriti.gr/neakriti2/index.php/main-page/
neakriti.
I found what was causing the problem in (1)
GD Library in my test server was not enabled.
I enabled it through php.ini and recreated thumbnails and it worked…
for (2)
The problem remains as I see the description outside the image
