Blank page in search engine
Hello everyone!
I have a recipe page (www.lasrecetasdeangy.com) and I have the mobile theme plugin activated and the theme in version 8.5.1 and everything works fine except search from both mobile and PC. If you try to find any of the recipes that I have in the blog, if you select any of the options that shows you there is no problem but if you click on the keyboard intro on PC or search on the mobile, redirect to a blank page and an error 414, could someone tell me why?
Thanks !!
Hello juanca1612,
For more information about this error, please check here -> http://www.checkupdown.com/status/E414.html Checking your website, I saw that you are using some untested plugins which can interact with the theme core files and causes a lot of unknown issues. Try to disable all of them, leave just to active only the plugins that come bundled with the theme core files and check the results. I saw that you are using a minified theme’s version which can cause some errors. Also, if the problem is still there, try to make a new clean install from scratch via FTP way to another sub-domain and check the results.
I have already been able to solve the error. The bug was in a security plugin, specifically the iThme Security that blocks me the long URLs to prevent attacks and the browser shows this type of url when it works, hence it will show me an error 414. It has been disable this option in the plugin and it has to work.
