Hello, I build my homepage with the tagdiv-composer and use block 14. If I hover on the thumbnail or the excerpt of a posting in the loop the block title of the post is getting invisible / white (background is white).
Is there a possibility to change this in the theme panel or is there a css code to change the color so that the block title is getting visible instead invisible?
Here my homepage: https://www.awayfromlife.com/
On categroy pages with block 14 there isn’t the problem (for example: https://www.awayfromlife.com/news/)
Hello AWAY FROM LIFE,
I guess that you have made some additional customizations through your website and that’s why you bring this error, sorry! I have tried to overwrite some CSS rule to avoid the transparent post title when you hover over it. Try the code below and place it in Theme Panel->Custom CSS area.
The code is ->
.td_module_wrap .td-post-category:hover{
background-color:#891200!important;
.td_module_wrap:hover .entry-title a{
Hello Catalin,
the code worked perfect. Thank you so much!
Best, Simon
