Hi, I have a problem with block-15. When I added for the first time, it has the classic grey background without post thumb.
However, when I add block-15 to another section, its layout is deferent and has the posts’ thumbs.
I am comfused and I don’t know how to fix that.
Here you can see a screen cast video showing the problem: http://marketpost.gr/docs/block-15-problem.mp4
I would appreciate your immediate responce because my boss has to a meeting in 4 hours and he will demostrate the website.
Thank you in advance.
PS. I also have a problem with block 9. I added the time stamp of the post before the title. But, if the title is too long, the time goes above it and breaks the layout. Is there a way to set a fixed number of characters for the titles or tell “if there is no more space, cut the title and show … “? Any hint for that?
Hello lazdim,
Ensure that you are not using any other untested plugins which can interact with the theme core files and cause a lot of unknown issues. Remove all of these, clear all the caches and check the results. To be sure, make a full backup to your database and re-download the latest theme packet and make a new install of the theme via FTP way.
For the latest request, regarding on title length, notice that our theme has an option for this, in Theme panel, Excerpts section. For more information about this, please check the following documentation here -> https://forum.tagdiv.com/excerpts-introduction/
