Block 16 – Infinite Load – Posts repeat
Hi, on this page of my website: https://www.buttonwoodmarketing.com/archive-news/ I have Block 16 set to Infinite Load. If you scroll down the page the Block keeps repeating posts, instead of loading all the posts just once and then stopping. All posts are assigned to just one category and also the page has ‘unique articles’ enabled.
How can I get the posts to show just once?
I am have tried swapping the Block 16 settings to ‘pagination – next / prev ajax’ and used ‘offset posts 10’. I’m using WPBakery Page Builder to put the page together. The page has ‘unique articles’ enabled. Articles are still repeating.
Note that you don’t can use both builders in the same time, so you need to choose between WP Bakery and TagDiv Composer.
So, I gladly recommend you to shift from WPBakery to Composer, because WPBakery is an old builder plugin.
Please check our guide to know how to shift from WPBakery to Composer: https://forum.tagdiv.com/visual-composer-tagdiv-composer-transition/
