Block 18 – Thumbs problem with stretch row
Hi all 🙂
I’ve a problem with block 18 thumbs if i set “stretch row and content” or “stretch row and content (with padding)”.
The thumbs, in this two cases, are too big.
I’ve two screens for show you the difference between default mode and these two modes!
How can i solve it? 🙂
Thank you,
Toni
They should not display like that when the row is stretched. This is how the block should be displayed when the row is stretched with content
https://www.screencast.com/t/kH0EHIrH
https://www.screencast.com/t/dENshw0uJsAR
Maybe something is affecting the thumbnail, if you could provide a link to your website where this is happening, we will inspect it.
It’s happening in the homepage, the site is http://www.playstationzone.it
Is necessary to apply the stretch row for show what affecting the thumbnail?
The homepage can’t stay in that way for a long time.
Best,
Toni
  • This reply was modified 9 years by ToniRM.
I have tried to replicate the layout you have and recreate the problem, but with no result. Stretching the row while using the block elements you are using does exactly what it should
https://www.screencast.com/t/XPjjZqxs69v
https://www.screencast.com/t/QCcpZorF
There are no problems with the thumbnails in that block on my end. A suggestion would be to disable all your plugins except the tagDiv composer, clear any caching installed and check to see if there still is a problem.
