BLOCK 4 read more not works correct with WPML
I use WPML to build a multi language website.
Then use WPbakery and Block-4 to add a category archived list page.
But the ajax read more function not works with correct language.
For example, WPML default is English, when I in traditional Chinese page to click read more button.
It will add the English post item but not Chinese item.
Is there anything wrong? How to fix it?
thank you
Page elements (meaning the content) don’t have to actually be translated. You can translate the page as a whole – https://wpml.org/documentation/theme-compatibility/create-multilingual-wordpress-websites-using-the-newspaper-theme-and-wpml/
You can translate pages for all the languages you use, build them with the composer or in the way you want. Then when the language is changed the page will be switched. If you need help or you have more questions let us know.
