Block 6 – Read More Not Showing
Can you help please? We changed our block to Block 6 and now the Read More is not showing. https://infomeddnews.com Thank you.
Please provide more details to what block you changed, where? And how did you change it so that you cannot reverse the process. If you changed it, can’t you simply change it back to what it was before?
Bogdan, I changed it back to Block 4 but unfortunately, you cannot see the Read More button. How do I fix this please on the home page at https://infomeddnews.com Thank you! : )
I don’t understand exactly what you are referring to. Block 4 and block 6 do not have Read more buttons
– https://demo.tagdiv.com/newspaper/block-4/
– https://demo.tagdiv.com/newspaper/block-6/
Block 12 for example has a read more button
– https://demo.tagdiv.com/newspaper/block-12/
If you mean the Load more, that is a block pagination
– https://www.screencast.com/t/Ibi0aA00
– https://forum.tagdiv.com/block-settings-guide/
Thank you. But how do I add a READ MORE block then to either Block 4 or Block 6 please? Thanks a bunch.
You will have to modify the module that block 4 uses, for example. Copy the read more code from a module that has it, in the module 2 that block 4 uses. In this example I have copied the code form module 11
– https://www.screencast.com/t/ZUPBLaHmj
In module 2 – https://www.screencast.com/t/BxASAZrF0Ti
The result is here – https://www.screencast.com/t/vfeLfPkAZL
So that can only be achieved through modifications to the module file. Either module 2 for block 4, or module 5 for block 6.
