I feel like a Dumb asking this but i can’t see where to Setup the Block 8 title color to be different from the others, since that one is supone to be White rather than Black or whatever obscura color i have configuren on the other blocks or site…
Any clue?
See the examples:
How is suposse to look:
how it actaully looks:
Hello j0suedaniel,
You should check the Theme panel settings from here -> https://www.screencast.com/t/siEUKfVgji For more information about this settings, please check the following guide here -> https://forum.tagdiv.com/theme-colors-introduction/
No you dientes understood what i said. Sorry if i dientes explained myself well.
Here is a more easy example.
Right now, i have my Live website and a Staing website where i am runing the Newsppaper theme with the old settings (that worked). I Will post the screenshot of the 2 panels configuren so you Will seee that it makes no sense for it to be like that.
Live Website (With Black text) Panel: https://www.screencast.com/t/kuYXwPqRQyUd
See this article (LIVE)
Staging Website (With White text) Panel: https://www.screencast.com/t/7Wkz9HhDc
Also see the articles so you Will get a more cleaner explanation. It doesnt make any sense
This reply was modified 9 years by
j0suedaniel.
Hello j0suedaniel,
Try to clear all the caches and check the results. If you need more assistance in this case, please send us an email at contact@tagdiv.com with your log-in information (wp-admin) so we can further inspect it closer your setup page. Provide there the link to this topic so we can quickly identify you.
After this, if you are using some untested plugins, please try to disable all of these and leave just only the plugins that come bundled with the theme core files and check the results.
Everytime I try to send you the email with the credentials, I receive a bounce error..
Please help! https://www.screencast.com/t/eOGislgu
Maybe this is a misunderstanding. If you want to change the article title color in the post page, this is the setting in the theme panel
– https://www.screencast.com/t/wYa6zzAc
– https://www.screencast.com/t/uEHu3muWpF
Resetting the color to default will look like this
– https://www.screencast.com/t/rJqXsTxQ
– https://www.screencast.com/t/W5No4co8
If you want to change the color of the post title only for that particular post template, you can use some CSS like this
– https://www.screencast.com/t/P24ueSe0
The code must be entered in Theme panel->Custom CSS section (with the color you want)
.td-post-template-8 .td-post-header .entry-title {
color: yellow;
THANKS – THAT SOLVE THE ISSUE
ANyway, i suggest you guys include an option for that kind of post tope, since no matter what color you have your site (Black, Blue, Yellow,White) the Font on top of the Black Overlay Picture of the post type 8 has to be WHITE
