Block 9 filter with AJAX CATEGORIES DROPDOWN not show up in secondary language
I setup a Block 9 in my multi language site with WMPL. It is showing fine with AJAX CATEGORIES DROPDOWN in English version. But when I change to the second language, the sub categories are not showing if I set a filter IDS. If I set for all categories, it is working.
So for the second language you have selected too the AJAX CATEGORIES DROPDOWN per block, if is so then it’s should be display correctly.
If there is still a problem, please provide me a link where I can inspect this problem.
Hi Calin,
I did select the categories with the same IDs. The site still under construction. you can’t see from the visitor’s view.Is there any other way I can send you the login so that you can have a look at it?
Hi, you can do it on private, via email, for this you can send us an email at contact@tagdiv.com also please provide as more details you can, also some screenshots will help a lot.
Include a link to this topic in the email.
Hi Calin,
I have sent the log in details to you. Please check and let me know if you need more information.
Thnak you.
Our team from email will handle your request.
Have a nice day!
I found the categories list didn’t update for the secondary language. But it is working now. Thank you so much.
I’m glad that the problem was solved!
Have a nice weekend!
