On the page where I write the posts, the block settings and category options have disappeared.
Thanks for any help.
Added: I don’t have the option to overwrite the default site post template anymore. That’s no longer showing on the bottom of the page where I write the posts.
DEFAULT SITE POST TEMPLATE
Setting this option will make all post pages, that don’t have a post template set, to be displayed using this template. You can overwrite this setting on a per post basis.
There can be a few situations. First, please make a test, install the classic editor, and see if the Post settings are displaying back. If the problem is resolved, then it is possible that in the Gutenberg editor, that option can be hidden or maybe moved to the right sidebar. In case the situation persists, it is possible that there is a plugin conflict with an extra plugin that is used; for this, please make a test using only the TagDiv plugins.
I haven’t figured it out yet. I did as Calin suggested above, including enabling the classic editor, disabling all the plugins and adding back the Tag Div plugins, but the post settings are still missing at the bottom of the page where I write the posts.
If you can provide WP-Admin access to investigate this situation, then please make a full backup for your website and contact us via email at contact@tagdiv.com and provide your WP-Admin access to check this situation. Also, explain the situation and include the link of this topic in email.
Mine weirdly came back, and I’m not exactly sure what I did to make that happen. If I figure it out, I’ll report back!
