Block and posts content's colors
Good morning,
for this theme https://demo.tagdiv.com/newspaper_city_news/
I can’t find where to change the colors of the block labels (NEW EVENTS, MUST READ, etc), as well as the hover colors of the news headlines.
The same is true when I open an article: I would like to change the colors of the labels in the sidebar and related articles.
I have already changed all the colors to the theme colors but these don’t change.
Thank you
To change the color of the blocks from the homepage, please edit with tagDiv Composer, select the block and change the background color => https://www.screencast.com/t/x68tDSQ9y for the color of category on the Standard Single Template, you need to set a color on each category from Theme Panel -> Categories => https://www.screencast.com/t/kJDdaQmeVQ8s -> https://www.screencast.com/t/SXpKwpcJIxvG
For Related articles and more from author, you need to use a custom code CSS =>
body .td_block_template_4 .td-related-title .td-cur-simple-item {
background-color: #EA2E2E ;
body .td_block_template_4 .td-related-title .td-cur-simple-item:before {
border-color: #EA2E2E transparent transparent transparent !important
You need to set the code in theme panel > custom code> custom css.
for the widgets from sidebar, you need to set the color in Appearance -> Widgets => https://www.screencast.com/t/UEot5Ezb -> https://www.screencast.com/t/gxNLadZ28
Hope this helps you!
Thank you so much!
