block, flex block e grid flex block: why I'have not block ?
HI ! I bought Newspaper for two of my websites. In the last one I bought, in Tag Div Builder there are no Blocks. There are only Flex Blocks and Big Grid Blocks. Why? I’m struggling more than the first site I made and which still has all the Blocks, so it’s not a question of updating. What do I have to do to get the 25 Blocks I have on the other site? Thank you
Those blocks are from tagDiv Standard Pack plugin, but I recommend using Flex Blocks instead of blocks 1-25; those are from the tagDiv standard pack and can’t be customized as a Flex Block; this plugin loads all the styles even if it is not used;
Thank you, Anamaria ! I found Blocks but I follow your advice to use the Flex Blocks ! Have a nice day !
You can import blocks from tagDiv Cloud Library -> https://cloud.tagdiv.com/#/single/page/Blocks/1817 The block will be set at the bottom page content, but you can move it where you want, select the row => https://i.imgur.com/ddupL4m.jpg
