Block header 1 on block 3 not the same as on block 4
Is there some way I can have an identical block header on both block 3 and 4? I like default one (Block header 1) on block 3, but the same template look very different on block 4.
I’ve tried to change some font settings, but I’m not sure which apply to the block heading. Thank you.
These would be all the available block header styles
https://demo.tagdiv.com/newspaper/block-header-1/
You can set a block header for each block – https://www.screencast.com/t/qXwIqi9q4l
Or set one in general – https://www.screencast.com/t/tUNW2HpN
If I misunderstand something please correct me.
All blocks are set to be “block header 1” but they don’t look the same. See the front page of the site: boostatv.com. Not sure what I did wrong.
I also wonder if there is a way to change title length on block 4 so that all of the text in the title is visible. The “title-length” under the “content-length” settings in the block settings is greyed out and cannot be changed.
All titles are less than 60 letters btw.
The latest articles title is different, that happens because of the gadgets demo design. When installing a demo there will be a custom design imported.
That demo uses block header template 5 with some modifications. Also it uses a bigger font-size and line-height for the titles.
What happened is that in the demo stylesheet there is some customization that will apply to a few blocks, for the block title
https://www.screencast.com/t/NHZRwuYCkz
If you remove the code it will not load anymore and the block titles will be as default.
Or edit the page with the composer and set the block title font properties manually, like this
https://www.screencast.com/t/z5YVIIkR
The result should be like this – https://www.screencast.com/t/fuLyuz1a
The length can be changed, simply click in the field and enter your desired value.
Thank you, it worked fine!
