Block Header location to be on the right side
How can I move the header block title to the right side as in the picture below
https://imgur.com/a/L0J6HvL
Sorry Wrong Picture please find below:
https://imgur.com/a/QkaWEEK
That is the Newspaper theme from what I can see, this is the Newsmag forum.
Newspaper has a few block header styles to choose from
– https://demo.tagdiv.com/newspaper/block-header-1/
Most of theme are left aligned however, or center aligned. This is because the right side is where the ajax filter is displayed
– https://www.screencast.com/t/gTQAf2T1Lzu
If you don’t plan on using ajax filters you could use some CSS
– https://www.screencast.com/t/U7XnTHaM9Ky
This code is general, it will affect all the block titles in the website when used
.block-title {
text-align: right!important;
Thank you for your replay. I misposted this here, it had to be on newspaper yes, but it worked thank you very much.
Best,
