Hello Ken0929,
If you want to change the headings for the block template style 8 you should edit the theme core files and make the following changes, like this -> https://www.screencast.com/t/DuMK3ZrKJ76c Clear all the caches and check the results.
Sorry I don’t understand.
I want to change h4 design(for”post”) to the same design(block template style8).
Do I need to edit the theme core?
I edited CSS like…as below. But it didn’t work.
.td-post-content h4 {
font-size: 20px;
font-weight: 800;
margin-top: 0;
margin-bottom: 18px;
line-height: 29px;
position: relative;
overflow: hidden;
.td-post-content h4 > * {
position: relative;
padding-right: 20px;
color: #000;
.td-post-content h4 > *:before {
content: ”;
display: block;
height: 4px;
position: absolute;
top: 50%;
margin-top: -2px;
width: 2000px;
left: 100%;
background-color: #f5f5f5;
Hello Ken0929,
You can put that code inside the Custom CSS because the theme will load it from there or if you want, you can add it directly in style.css. Notice that all of these involves additional customizations which are not covered by our support, sorry!
