Block not formatting right.
On this page at the bottom of the article, I have a 3 column 2 row block that for some reason is only showing 2 on the top row, and creating a 3rd row on the bottom with 1.
Why is it doing this? None of the changes to the settings that I have tried fix it.
https://podcastmovement.com/faq/best-podcast-microphones/
There is a set option that makes the third element in a new row, you need to use a custom code CSS to make to display the block normally => https://www.screencast.com/t/lbwddqidite
.single .td_flex_block_1 .td_module_wrap:nth-child(3n+1) {
clear: inherit;
The code needs to be set in Theme panel -> Custom code -> Custom CSS => https://www.screencast.com/t/fxetQe24ZHf
Hope this helps you!
Thanks! This worked!
Now I am having an issue with the 2 column one: https://podcastmovement.com/faq/best-podcast-microphones/
Please try this code
.single .td_flex_block_1 .td_module_wrap:nth-child(3) {
    clear: inherit;
Set the code in Theme Panel ->Custom code -> Custom CSS ->
