block problem after theme update
Hi!
I need your help asap! the design I had changed… I am using NewsmagVersion: 4.0 with child theme supplied with it. previously I had same settings. I just deleted old main and child theme and replaced with new one… Now after the new update my blocks looks different plz check here http://seaothouston.org
1. you will see how “block 1” appeared wrong..the small posts should be at the right side but they are coming below the big one.. How to fix that? I want same look as https://www.dropbox.com/s/e42vcu8p6qkn8hd/lookCapture.JPG?dl=0
2. Also can i get the 5.1.2 version of the wpbakery? https://www.dropbox.com/s/1urt47iwz9uznjx/wpbakery.JPG?dl=0
the plugin panel showing there is an update.
Hope to get a reply soon. Thanks for the help in advance!
Regards.
Satabdi B.
1. I have inspected your website, but there is no problem like you mention with the block
– https://www.screencast.com/t/ONFPAc8g3Vff
The block is displaying properly form what I can see.
2. The version of Visual composer provided in the latest theme package is 5.2. We will provide updates for this plugin within a theme update. Each plugin update will be tested before, to ensure full compatibility. Do not update the plugin if you have a separate purchased licence for Visual composer, this could create problems.
Hi Simion,
Thanks so much for the quick response, after I read your msg I checked again, in Google chrome it looks fine but in Firefox browser the problem is there plz check https://www.dropbox.com/s/3qb4nbp61aaa58u/Screen%20Shot%202017-08-23%20at%2015.16.36-fullpage.png?dl=0
I have cleared cache, refreshed browser several times, no changes happening, it looks weird. have you checked the site in firefox? Plz help to solve this issue. Hope to hear soon.
Thanks so much again!
You have the browser window zoomed out. Please zoom in back to 100% and the problem will be fixed.
wow! Thanks so much 🙂
