Still having ‘green’ color when hovering on post titles in block sections.
Screenshots:
https://www.dropbox.com/s/kuyv7rplndj2sk8/Screenshot%202018-09-07%2015.13.31.png?dl=0
https://www.dropbox.com/s/2opgp2ne1wa5zny/Screenshot%202018-09-07%2015.13.22.png?dl=0
Can you please assist?
If you have trouble getting access to website mrrwebdev01.org, please let me know what your IP address is and I can whitelist you.
Hello bob,
Try to use the code below ->
.td_block_11.td_block_wrap a:hover{
color:red;
Notice that color comes from your Theme Accent Color which can be set up from Theme panel from here -> https://www.screencast.com/t/nsv9lzoxsR11.
Thanks for the reply and info.
Our color was set to #1e90ff, but the blocks still don’t follow the rules of that.
The CSS code that’s been provided didn’t work however. The hover color is still green.
Will I need to add custom CSS for each of these different blocks, or will this be fixed in a new release of the theme?
Screenshots:
https://www.dropbox.com/s/mo8n90kbn5rw8z4/Screenshot%202018-09-10%2010.48.18.png?dl=0
https://www.dropbox.com/s/aul84q4m548q8rn/Screenshot%202018-09-10%2010.39.56.png?dl=0
Thanks again.
Hello bob,
If you will use the TD Composer to create your page, notice that for each block you can change the hover color link from here -> https://www.screencast.com/t/uJslhqeP
Hi, Catalin.
TD Composer is not saving the changes to “Title text color”.
Screenshots:
https://www.dropbox.com/preview/Screenshots/Screenshot%202018-09-11%2013.00.44.png?role=personal
https://www.dropbox.com/preview/Screenshots/Screenshot%202018-09-11%2013.02.51.png?role=personal
https://www.dropbox.com/preview/Screenshots/Screenshot%202018-09-11%2013.06.39.png?role=personal
I can give you access to the website if you will provide your IP address.
Thanks again.
This reply was modified 8 years by
bob@mrrogersweborhood.com.
Clarification – It’s not changing the ‘post title color’ of the posts within the block.
Hello Bob,
Unfortunately, I cannot see your screenshots, sorry! Please send us an email at contact@tagdiv.com with your log-in information (wp-admin) so we can further investigate it closer to your setup page. Provide there the link to this topic so we can quickly identify you.
Hi. I’ve sent the email with the credentials. If you are unable to access the website, please let me know your IP address and I can whitelist it.
Thanks again.
