Block shortcode grid problem
Hi! I’ve a problem when I use the modules block short code, the items post appear to be one below the other. Somebody can help me?
No, I’m referring to block short code in the home page. For example https://demo.tagdiv.com/newspaper_black/ “the word news” block doesn’t look like the link in the demo otherwise they post appear to be one below the other.
All the blocks from the homepage can be edit using tagDiv Composer -> http://prntscr.com/pq0zfl -> http://prntscr.com/pq0zqx
If this is not what you mean, please provide some more details!
I am using tagDiv Composer but when I drop the block doesn’t look like the demo the posts are showed to be one below the other. As if it was broken.
The example you mention – https://prnt.sc/pqjt5k is block 1, which looks like this
https://demo.tagdiv.com/newspaper/block-1/
Most predefined blocks Blocks (1->25) look different when placed in different layouts (1/2/3 columns).
What exactly is the problem you are facing? provide a link to where the block in question can be seen. I will inspect it to see if there is a problem with it. Let me know.
