block – sort order – random posts keep showing same post
With block 14, I filtered with category(have 16 posts).
and sort order – random post, pagination – Load more button.
when I press load more button, it shows same post until 16posts.
What’s the problem?
That should not happen. Maybe you have enabled the Unique articles feature for the page
– https://forum.tagdiv.com/unique-articles/
Having this option enabled in combination with pagination, will result in duplicates.
I have tested the same block with the same post sorting and pagination, and there are no duplicates in my case, with the unique articles disabled.
It won’t work for me.
01
02
03
I found about this problem.
https://forum.tagdiv.com/block-settings-guide/
Team said “Do not use the random posts sorting options together with pagination as it could result in duplicate posts.”
