Hi, please see attached image: https://imgur.com/a/usHXbWz
I would like to make the block title fonts and bg bigger on the homepage but not on the widgets title inside the article. I see that they are linked together, even in the theme panel if you modify the font or font size its going to affect the other widgets too.
Found the code in the source which is something like this h4. td-block-title but its the same as the text title from the sidebar from inside the article. Is there any solution to this? đ
If the homepage is made with tagDiv Composer than you can open the page with td composer and select the title and set the size and weight https://www.screencast.com/t/pgfjMx4Ua8DR
