Block1 post title width problem
Hi there,
I’ve done installing your theme to my site at http://www.infokomputer.com
After doing some adjustment and setting, i’ve found problem with post title in block1 homepage module. It didn’t fill enough width, so the right side seems too much space (blank). I’ve try to change module setting, but no joy.
In your theme sample, Block 1 module looks perfect. How can i get excatly like that?
Brama
Did your “adjustment and setting[s]” possibly offest the block1 homepage module?
If your CSS is in the child theme (as recommended when customizing themes) you could try deleting all new CSS, saving the file and refreshing (after cache deletion). If the issue is gone then you know it’s the CSS and you can revert all your CSS back and hunt out what’s causing the issue.
I see that you have .JS errors in console. Please deactivate some plugins and see if works. Also please disable is you use minify to see if work.
Hi, thanks for your answer.
I’ve found the problem. It’s on the Page Attributes – Template. I must use “Template-Blank” instead of “Default Template”
Regards
Great!
