When you go to your blockchain pro demo and open a blog post and start scrolling down, the floating sidebar is cut off. The sticky menu is covering the sidebar widget “Related”. How to adjust the widget to make sure the title of the widget is still shown?
Pleaase try to use this custom code css
.td-is-sticky .clearfix{
margin-top: 80px;
The code need to be inserted in Theme Panel -> Custom Code -> Custom CSS => https://www.screencast.com/t/0Lb8nbD7s5u
Hope this helps you!
