i want to add specific posts in different blocks. How can i do that?
i realy need this.
thank you.
The theme doesn’t have an option to display post in blocks filtered by post id. To display a specific post in more blocks you can add it in a specific category, then use that category’s id in block filter. If you’re using this method, you will need to specifies in categories filter field and the others categories ids which you want to display in that block, otherwise will display only the post from that specific category: http://screencast.com/t/K00fgJFhnlf To get the category id follow this link: http://screencast.com/t/9DtA1pu7Q3Dx
Hope this help.
I know the method with the category but i wanted to know if there is another option.
i read a topic with something like that for newspaper theme.
will you consider introducing this option in next releases? It is a very important feature.
thank you.
Thanks for the suggestion, I’ve added it on our list and will consider it if we decide to add new features for blocks in future. However I can’t promise anything in this regard as we have a large list of request and we must pick carefully what we will implement.
We added the post id filter so if you want to use this feature just update the theme at the current version available on themeforest, V 2.3.5. Here is our documentation in this regard: https://forum.tagdiv.com/newsmag-how-to-update-the-theme/
