Blocks not appearing correctly
The blocks seem to become one column. For example we used Block 1 that has a large picture on the left and smaller pictures (4) on the right, but instead of it being two columns, the smaller pictures are forced under the large picture and creates one column. Here is a image showing what is happening.
http://azoutdoormagazine.com/dev/wp-content/uploads/2015/12/error2.jpg
Can you please let us know how to fix this?
Hello madeyoulookstudio,
I have checked your screencast and I saw what’s the problem. It seems to be an issue might be caused by conflicting plugins. Please try to disable all the active plugins, except Visual Composer, clear all your caches and install only the plugins that come bundled with our theme. Also, please check your custom modification if you have some changes for this kind of block wich could cause this layout damage.
Let us know how it goes and if you need more assistance after you have followed my solution, please provide your website URL so I can further inspect the issue.
Thank you for the message!
Thank you! This worked. We had two conflicting plugins from the previous theme and the new.
