Blocks on my Homepage are not showing up on Mobile View
I recently updated my theme and recreated my homepage. However, I can see that none of the blocks that are visible on my desktop view is showing on the mobile view.
How do I fix this?
Regards,
Joshua
I’m sorry but I don’t understand your message. Can you provide me with some information?
Like screenshots, a link to your website.
Here is a screenshot https://postimg.cc/z39YCKZ5
The block in the image is only visible when in desktop or tab mode. It disappears completely when viewed on mobile. All the blocks on the page follow the same pattern.
https://www.nycinsiderguide.com/mobile-home
Here is a link.
When you compare desktop and mobile view, some blocks are not visible on the latter
I just inspected your website and now seems the block called “Explore NYC Safely” is displayed also, on mobile => https://www.screencast.com/t/fiSVnNYGXUwf -> https://www.screencast.com/t/bc8dKy8VFn99
Did you manage to solve your issue?
