Hello
When making a post (with no sidebar) and using either blocks or grids within the post to link to other content, the blocks/grids do no align center, rather sitting to the left and leaving a large amount of white space. I have updated my development site to the latest version of Newsmag, as well as VC but the problem still is apparent.
Any ideas?
http://www.mcnews.com.au/newsite/wp-content/uploads/2017/11/tagdiv.jpg
Hello PAPPACLART,
I have inspected some post articles from your website but I do not see any problems with your alignment. Please provide the certain URL which the problem appears so I can take a closer look at it. Clear all the caches and check the results.
Hello Catalin Thanks for the reply.
Very few of my articles have no sidebar. I noticed the problem when I decided to make an article without a sidebar. The articles with a sidebar are fine.
http://www.mcnews.com.au/2018-honda-gold-wing/6/ Just to show you, at the bottom of the page I added a slider block and as you can see it aligns to the left. Any Newsmag specific block/grids I add to a post page (with no side var) will always align left. Normal VC elements will align correctly.
The above example is on the live website. Like I mentioned I updated my development site to the latest version of the theme and VC and still have the same problem.
Also, and additional issue, sometimes as you will see in the link that some visual composer code shows.
Regards
Ryan
This reply was modified 8 years by
PAPPACLART.
PAPPACLART.
Hello PAPPACLART,
If you have TD Composer active, try to disable it and use only VC Composer because if you have both plugins active, might appear some conflicts. Also, if you are using other untested plugins, try to disable all of them and leave just to active only the required plugins, clear all the caches and check the results.
Hey Catalin Thanks for the reply.
Tagdiv composer is not active on the main site. It is active on the development site but have already unactivated it and tested before and it makes no difference to the issue.
On the development site, with only VC activated the problem still persists – http://www.mcnews.com.au/newsite/rossi-is-the-greatest-of-all-time/
Regards
Ryan
Hello PAPPACLART,
Try to make a new clean install from scratch via FTP way because this is the surest theme method, clear all the caches and purge CDN files if you are using Cloudflare and check the results. Also, if the problem is still there, please send us an email at contact@tagdiv.com with your log-in information (wp-admin) so we can further inspect it closer your setup page. Notice that before each theme install, you should make a full backup to your database to avoid losing your data.
Hello Catalin.
Thanks again for your reply and efforts.
I have reinstalled the theme with no luck. I do not use a CDN. I also have a licence for Newspaer theme which does not have the problem after I installed it and tested.
I will e-mail over the login details for the test site.
