blog post section not showing more than 6 posts
I have a problem on my posts category section where it won’t show more than 6 posts.
There is also no option on bottom of page to go to page 2 or page 3 to see more blog posts.
How do I fix this?
If you use a cloud template, please check the settings if you have set up a limit or an offset and let it empty with no space, no value.
Let me know the results!
I’m using a flex block/big grid flex. Can you tell me how I can make it show more than 6 posts and the rest of the posts in a category shows in page 2, page 3 etc?
https://weedinsider.ca/reviews/
Please edit the page with TagDiv Composer and please check the element’s settings. Let the offset field empty with no space, no value, then the posts will display. Check also the filter.
Hi Bettina,
Sorry but I am having trouble finding elements setting after clicking edit TagDiv Composer. And what does offset field empty space mean?
Hi weedinsider.ca,
This https://weedinsider.ca/reviews/ is a page not a category, but you can edit it using tagDiv Composer -> https://i.imgur.com/6zy8zjM.png click on the flex block and you can check the number of posts from here https://i.imgur.com/JdImJXq.png also you can add pagination from here -> https://i.imgur.com/WMxVE7s.png or if you want numbered pagination, then use the posts loop element https://i.imgur.com/h2yO3rm.png
I hope this will help you better!
Hi Calin,
Looks like my last message didn’t send through.
I have done what you said but this flex block also appears on beginning of home page as well as on top of each of the individual “review” blog post.
Any ideas on how I can just show this flex block on the category page itself and not the home page and individual posts?
You can edit each template individually. If let’s say you edit the Category template for the category News, the settings done there will remain there. If you want a flex block to display more posts all you have to do is to use this setting: https://www.screencast.com/t/h3zZmg4EdZ ; If you want that flex block to display all the posts from your current category you need to use this filter: https://www.screencast.com/t/FVVdhmeu13G
You can duplicate this template for multiple categories and edit it for each one.
But when I delete the flex block from the home page, it is removed from my “reviews” menu category as well.
What I need is for the flex block I chose to only appear in the category I selected which is under my “reviews” menu of the site, not home page.
Any ideas?
I feel like I’m not explaining properly.
I have attached this google here to show better, thank you.
https://docs.google.com/document/d/13kM4m_1vd6ohyghtbjIiAwLlxayqlsdp4XeOmu6_Aus/edit?usp=sharing
This is a flex block 1 element and you need to edit every category with TagDiv Composer and change the filter: Current category in order to display the posts from the current category. If you want to delete this element, you should duplicate the template and make the changes. If you have the same template for all your pages, then this flex block will appear on every page.
How do I make a new template? When I delete the flex block from one of the categories, it also deletes from all the categories
Please just let me know how I can show ONLY each category posts on each categories on the site.
Right now, when I change anything or load a template on a category page, it shows the same thing on all category pages…
If you want to have the same category template for all categories, but with some changes, then duplicate the existing template and for assigning another template go to Newspaper -> Theme panel -> Categories -> Select a category you want and there you can find the setting “Category cloud library template” and choose the template from that dropdown for each category, also you can change the title of template for each category => https://www.screencast.com/t/BMP2o0nqJ
When you set a block on a category template, you need to set the filer on the Current category => https://www.screencast.com/t/hAAhXSJ5 to display the posts from that category.
Hope this helps you!
Thank you SO much. This helped me!
Do you know why the categories are showing 2 grey lines on the right of the page on each category pages on the site?
Can you check and see why this is happening?
Website is found here (i also show what it looks like): https://docs.google.com/document/d/13kM4m_1vd6ohyghtbjIiAwLlxayqlsdp4XeOmu6_Aus/edit?usp=sharing
Please edit with tagDiv Composer, and see if that zone you have a row, please delete it and see if, after that, the lines will still show.
I have tried deleting the row but there is no option to delete?
Please see what I mean here: https://docs.google.com/document/d/13kM4m_1vd6ohyghtbjIiAwLlxayqlsdp4XeOmu6_Aus/edit
You need to delete the row like in this video => https://www.screencast.com/t/4iahCpl8IXij
thanks so much!
Hi, my homepage shows social media icons on top right
How do I remove this again?
Also, second question:
https://docs.google.com/document/d/1UcOMHkR6OQYA-pOMgLIMc3zJG4PBRDmips8yDLegotM/edit?usp=sharing
^Can we upload product informational pages like the one above? I only see posts and pages on newspaper theme so not sure where to do so.
Thanks!!
For the social icons simply remove them from Theme panel as you can see here: https://www.screencast.com/t/rBGB1by8
For the product template please note that the one from the example website is done via an image, that is not made from the website.
yup nothing is on the social icon section, but the facebook and Instagram is showing on home page?
Please use this css code: .tdm-social-item-wrap {
display:none!important;
The codes must be inserted in here: https://www.screencast.com/t/G4qVwC6G
thanks!
Viewing 25 posts - 1 through 25 (of 27 total)
