I am having an issue with all featured images on my website.
It is strange because it used to work well until a couple of weeks ago.
On some posts the image is on the left and on some others it is zoomed in, here below a couple of examples:
http://www.hackersales.com/successful-opening-lines-for-your-sales-emails/ (zoomed in)
http://www.hackersales.com/sales-activities-must-understand/ (on the left)
I haven’t changed anything in the setting. The only thing that happened is that i changed hosting for the website.
Luca
Hi Catalin,
Please see here below the examples that I highlighted earlier.
https://www.dropbox.com/s/zhi5pn79kl0chsr/Screen%20Left.png?dl=0
https://www.dropbox.com/s/ideyw860egolxwo/Screen%20Zoomed.png?dl=0
I am not sure how to explain in more details the issue. It’s really just a matter of sizing/centering the featured image that appear as a main picture for the blog post.
Luca
It seems that a theme class that is required to load is not working properly. Please try as a test to disable all your plugins except Visual composer, clear your cache then check to see if the problem is still present. Usually plugins are to blame regarding image problems. Let us know how it goes.
After further investigation it seems there is a problem with this post template, in the current version.
This issue will be fixed as soon as possible. We are very sorry for any inconvenience created.
In the meantime you could use this code to see if it fixes the image in this particular post template
– https://www.screencast.com/t/koQAE6JQxCRB
– https://www.screencast.com/t/eMr4TRm8SGxc
Try entering the code in the Theme panel->Custom Css
.td-stretch-height {
height: 100%;
width: 100.03%;
margin: 0;
position: relative;
Thank you for understanding!
