Blurry Images
When I place an image as Backround Image on a Row the image becomes blurry. Any suggestions on how to fix this?
The background image can be blurry when the image is smaller and need to be stretch or when you have set a smaller thumb for that image, make sure that you set the full size for the image that you have set as background, for example -> https://i.imgur.com/A9lX4Ok.png -> https://i.imgur.com/UVlTXgy.jpg
Hope this will help you!
