body background image – not working..?
I know this sounds silly.. but I’m trying to set up a background for the site.
So… I go to Theme Panel > Background and I select a background image there.
Settings: No Repeat – Left – Fixed – Stretch Background.
All is well.. but then.. I save this and open up my homepage. There is NO background there, or on any other page whatsoever (post or category page). What am I missing??
That would be unusual. Do you use any caching, or have a caching plugin? try to delete the cache and check again. Check with a different browser as well.
If possible set a background and after that provide a link to the website and I will inspect it.
Hi Simion,
Thanks for the response.. I turned off all caching, deleted the cache manually (to make sure it was all gone) and it’s still not working.
Temporary staging url: http://azbw.cornerstws.com/site/
It looks like there is no background set from what I can see. If you have one set, then there is a problem.
We could take a look if you can provide admin access at contact@tagdiv.com maybe we can identify what is the problem.
We may need to deactivate all your other plugins, or you could do that an mention it in the email.
Please also include a link to this topic in the email.
Thanks Simion, I just did this by email..
