Body banner ads incorrect size
We should be able to use 728 x 90 ads within the body of our posts. However, your theme is cutting them down to 696 wide. How can I fix this? I use the Ad Rotate plugin, and when I upload an image and a link it shrinks it fine but when an advertiser gives me html, it just cuts it off. We need it to actually allow for a 728 wide ad.
Any help would be greatly appreciated.
  • This topic was modified 10 years by pdamon.
Hi cboettner,
Please provide your website URL so I can inspect it closer your Ad and also, please provide a useful screenshot by showing the problem.
Thanks for your message!
Thanks so much. I don’t have a screenshot, we had to take it down and put a corrected ad from the advertiser in its place. It was cutting off the right side of the image. But the ads dimensions were 728 x 90, and the size on my desktop shows 696 x 86.
Our URL is http://dieselgasturbine.com
This issue applies to any of our banner ads within a page or post body.
Thank you for your help!
Catrina
Hello cboettner,
Please notice that this is the max width of the theme for 2 columns and that’s why the theme will crop at this dimension. If you want to display the add to at large width you will have to get rid of your sidebar.
