Body Content Under Sidebar
Ok, so theres no additional plugins installed, and I’m not using a child theme. I have both TAGdiv and VC activate and when I posted an article the body content is under the sidebar…again.
Now I was told once that I can’t use the two composers together, then I was told by another person that it should be fine. Can you please help?
http://streamtheplanet.com/cord-cutters-growing-faster-expected-56-6-million-people-reported/
Ok, so I mentioned in another topic that I had to move newspaper theme to another site, because it wasn’t working well on my stream the planet site. I’m not going to use newspaper anymore on the other site and just use it here. So I’ve tested this exact same setup on another site. And I can duplicate the issue. So both TagDiv and VC are active, I create the post and body content under side bar
https://milai.love/kawaii/
I’m also testing the woocommerce on this site, and it seems the related products is broken.
https://milai.love/shop/iphone/squishy-cat-phone-case/
Hello barronlau,
I have inspected your website and I saw that your sidebar is broken and overlaps the content. First of all, I will recommend you to disable all of the untested plugins, if you are using something like this, clear all the caches and check the results. Also, if the problem will persist to be there, you should make a new clean install from scratch, via FTP wat with the latest theme version and check the results.
Hi Catalin,
Thats what this site is, it is a brand new site clean install. Its the same problem as the other site I tried to use the theme. Other the WPML and woocommerce I have no other plugins. Please help as the issue is consistent.
https://milai.love/ja/?p=2556
Here you can see the content under the side bar
http://prntscr.com/gnx9ca
Again if I disable Visual Composer its ok, it goes away.
Hello barronlau,
I have inspected your website and I did not saw any problem in this case, sorry! Please check here -> https://www.screencast.com/t/OTa8cOaj
