Body – general font – verdana vs Posts font
Hello
On our test site, I notice that the post text is in Verdana (you could see that with the excellent WhatFont plugin for Google Chrome):
http://www.virtualmagie.org/articles/critiques/matos/photoshop-de-will-tsai/
I deactivate some plugin but nothnig change.
In admin theme fonts, there is no Verdana define.
Only OpenSans, Roboto, Ralemway and some other for some specific part.
But mostly all is in Default font.
With WhatFond when you pass your mouse outsite evenrything, it is the Verdana which is define.
I just try to change in Body – general font from Default font to Open Sans and it works.
So it seems to be a a bug.
Regards
The Verdana font is the default one used on post content – http://screencast.com/t/omk8OIw9Ahttp://screencast.com/t/QuYXLIKsyCV
I’ve tested it on my side and it works fine – http://screencast.com/t/8g3Ej74WKrB4http://screencast.com/t/ZprqWj5Zhttp://screencast.com/t/cNEfRLnp6L1
Try to disable all plugins, save the settings in Theme Panel -> Theme Fonts and see if the issue is still there.
