Body of my post does not show
Everything is fine as long as my article is in “draft” mode; it displays correctly. But when I switch it to “published,” the body text doesn’t appear.
Thanks for your help.
Post: https://www.stefanegirard.fr/histoire-vin-origines-empire-romain/
Maybe you’ve set that post back to draft because it leads to a 404 page for me. I checked other posts and the content seems to be displayed, for example this one https://www.stefanegirard.fr/barbe-incomplete-zones-clairsemees-faut-il-insister-corriger-ou-styliser-autrement/ displays the content -> https://prnt.sc/xUdisDTCDu_l
Is it happening just for some posts perhaps? If all the posts use the same post template as the post I checked, they should all display the post content.
Let me know.
I’ve created a lot of articles recently, but now all new posts trigger this error. I deleted and recreated this one: https://www.stefanegirard.fr/histoire-vin-origines-empire-romain/. The problem persists. Older posts do display correctly. I tested switching templates, but that didn’t change anything.
This new link you provided also leads to the 404 page for me -> https://prnt.sc/QPdsQ-jLfLjO
Please let’s clarify what the problem is.
The links you have provided so far lead to 404 errors, so I can’t see those posts. Is this the problem? If these posts are published but they lead to a 404 error, the first step is to resave the permalinks -> https://prnt.sc/pO-qzg9DZN80 Simply press that button. Then check if the posts pages work.
But if the problem is that the body of the post is not displayed, so far I have yet to see a post with the problem. Please let me know how or where I can see the problem exactly. If you want, I can check directly on the website as an admin, you can send us an email at contact@tagdiv.com and provide an admin account (user and pass).
