Body Width
Hello, how do I increase the width of my post?
Like this website for example http://www.familytentinfo.com/best-beach-tent-review/
Also how do I change the thumbnail size of the featured image on the homepage?
There is no option in the theme to change the width. The theme is designed with a fixed width, and it is not recommended to change it, because it will damage the layout. All the elements on the page are directly dependent on this fixed width.
The featured image set on posts is displayed on the blocks and other elements that are used to create a page in the Visual composer editor. I see that you are using a different editor then the one provided with the theme to create your pages. I do not know how I could help you in this matter, it is recommended to use the page editor provided in the theme package – https://forum.tagdiv.com/how-to-use-visual-composer/
Im using the normal editor, the above site is not mines I was just using them for the example.
Here is my site http://africanamericanhairstyles.org/
As you can see the featured images are pretty small on the homepage, how can I make them bigger?
I fixed the thumbnail issue.
So do you have any idea how I can get my website’s width like the below site?
example site: http://www.familytentinfo.com/best-beach-tent-review/
my site: http://africanamericanhairstyles.org/how-to-grow-african-american-hair-faster/
You would need to modify the style classes in style.css – or hire a developer to massively customize theme.
you could first try making the layout width wider in the stylesheet to see what happens 😉
Maybe I am misunderstanding this again, but the example you provided and your website have the same container width
https://www.screencast.com/t/uhiU3JChdS
https://www.screencast.com/t/zdaU76TBu
If you would like to modify this width or any other width related element, you could try and change it in the theme stylesheet as Chris suggested above, and see the results.
